Old 08-07-2013, 02:06 PM
TacomaMan.'s Avatar
TacomaMan. TacomaMan. is offline
Check engine light 2008 silverado z71
recently my check engine light came on, I had the codes read, the tech said that i had air getting into my fuel system, i replaced my gas cap. my light is still on, he also mentioned some kind of emissions sylinoid may need replaced, or a vent valve idk.
I recently drove up to Sandusky OH for the weekend, my light didnt come on til i refuled with gas containing 15% enthenol. the engine is running fine, no miss, has good power. I ran it down to a 1/4 of a tank and filled back up and the light is still on.
Old 08-07-2013, 03:09 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Check engine light 2008 silverado z71
Is your truck "Flex fuel" compatible? If not, E85 will set lean codes.
Old 08-07-2013, 04:42 PM
j cAT j cAT is offline
I had the use of a chevy flex fuel for a while. used E85 the lower cost does NOT make the use of this fuel a good deal. we are getting screwed with this cost for lower MPG fuel.
on the code issue you may need a new canister or vent valve/cleaning vent line issue. If you fill you tank to the very top then park it this is a common code.
liquid fuel causes the canister to plug up the venting valves/lines.
you could also have a leak like the vent line in/around the fuel tank another common problem.
The Following User Says Thank You to j cAT For This Useful Post:
TacomaMan. (08-28-2013)
Old 08-28-2013, 05:49 PM
TacomaMan.'s Avatar
i actually found that the canister has a crack, i had to order one, I used epoxy to seal the old one up, will it be ok like that for a few days?
Old 08-28-2013, 07:52 PM
the canister sealing with an epoxy compound good for solvent use will work for a while . sand down the surface to ruff it up then use a solvent cleaner and apply the epoxy. I have seen this work in many areas in this case it is vapor. now if the fuel tank had a leak then you would require it to be replaced ..
put the gas cap on loose until the epoxy is cured.
