Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-04-2013, 10:46 AM
badd_maxx23 badd_maxx23 is offline
back door window
hi everyone i have a 97 malibu w the 3.1, the back driverside door window wont go down unless i push it down, if i only use the switch i hear the motor working it appears it came out of the track that operates it. I would like to know how i can repair this myself thanks
Old 08-04-2013, 01:22 PM
Tech II Tech II is offline
Re: back door window
so if you push it down it goes down.....does it go back up by itself, if the up button is pushed?
If yes, than it seems the window is not attached to the regulator.....you will have to remove the door panel to see what is broken.....
Old 08-04-2013, 11:32 PM
goes up like normal
Old 08-05-2013, 09:46 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
As Tech II stated, You will need to remove the door panel and do a visual inspection, there are a few different conditions that will cause this.
Old 08-08-2013, 07:59 PM
j cAT j cAT is offline
the plastic guides break . this can happen with age or someone used a bar to force the window down breaking the plastic guide.
