Old 08-04-2013, 08:36 AM
lbranham1101 lbranham1101 is offline
stutter
92 c1500 5.7L
everytime i start and put n reverse i had to rev it before i can reverse or it will die, when in drive if i barely put my foot on the gas it stutters like its not getting fuel or a misfire or something. i have changed just about every sensor there is, aswell as plugs. it only stutters when lightly on the gas pedal.
*about once a month* after driving about 50miles when you let off the gas going down the road it starts loping real bad, drops about 4-600 rpm until it dies.
anyone have similar issues or ideas?
Old 08-04-2013, 09:42 AM
Tech II Tech II is offline
Re: stutter
Could be a low idle.....check the throttle plate and bore and also the IAC....
Could be fuel pressure that's marginal.....last time fuel filter changed?
See how the vehicle reacts with the MAF disconnected.......
What kind of fuel injection system do you have?
Have you checked for any engine codes?
Old 08-04-2013, 05:18 PM
Re: stutter
what am i looking for on the throttle plate/bore? IAC is good, i just replaced it. fuel filter i havent done yet.
TBI for fuel system
no code check so far, going to do so now
Old 08-05-2013, 06:57 PM
Re: stutter
codes cant be read due to it being a 92. i dont have a scanner for obd1 so.
Old 08-05-2013, 09:07 PM
Re: stutter
You can do flash codes.....ground A to B in the ALDL connector, then turn key to on, don't start.......count the flashes....
