Old 08-03-2013, 06:33 AM
deerefeed deerefeed is offline
2002 blowing fuse 29 Auto headlights/O-Drive
Fuse 29 was blown when I got my truck, automatic headlights and overdrive lock didn't work. I replaced the fuse, the lights came on and overdrive locked out but when I shifted into park the doors locked and the fuse blew. Any ideas how the door locks are related and why they would lock when shifting to park?
Old 08-04-2013, 02:35 PM
jyount jyount is offline
Re: 2002 blowing fuse 29 Auto headlights/O-Drive
Yes, the overdrive button on the shifter has two wires, one of them is chaffed and shorting out, most likely on the steering column right behind the wheel under the plastic covers. Mine had the exact problem. If you have keyless entry the fuse is common to that too. That is how I found mine, had to key it to unlock it. Mine didn't have auto headlights so I had to do it manually anyway.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
The Following User Says Thank You to jyount For This Useful Post:
deerefeed (08-04-2013)
Old 08-04-2013, 03:00 PM
What's involved in taking the steering wheel cover off? I would think the air bag needs to be disabled. Can I disconnect the overdrive lock wires somewhere more easily accessible?
