Old 08-02-2013, 11:10 PM
HADLEY3119 HADLEY3119 is offline
2000 chevy blazer transmission shift issues
2000 chevy blazer transmission issues2000 chevy blazer,transmission shifting from 1 st gear to 4 th gear. Changed trans and second trans doing the same thing. Changed tps sensor also. Truck seems to do ok when it shifts to high gear, but rpm gauge goes very high before it shifts. Anyone experienced this problem please share your diagnosis, it would be greatly appreciated.thank you hadley3119
HADLEY3119
Old 08-03-2013, 08:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 chevy blazer transmission shift issues
You either have another bad transmission or transmission computer or bad wiring.
You need to get it on a transmission capable scanner and get codes and read out transmission data.
Post back any codes.
MT
Old 08-03-2013, 11:08 AM
Tech II Tech II is offline
yes, it amazing how proper diagnosis, if followed can save a lot of money....
Many times, have seen transmissions changed, and the problem was a broken wire in the harness somewhere, that controlled a shift solenoid.....
Was this a garage that diagnosed this and said you needed a tranny?
