Old 08-02-2013, 01:56 PM
ASE AMD ASE AMD is offline
a/c problem...
Got a problem here I can't understand. Its a manual system with one blend door adjustment knob. If its set to max cool its ok but one click towards heat and the drivers side gets hot. I removed the blend door assembly and I can't see anything wrong except possibly a design flaw as it seems to open much more on one side then the other. But I know it couldn't have been this way new from factory. The accuator is good btw. Any ideas or anyone seen this?
Old 08-16-2013, 12:31 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: a/c problem...
Might be a vacuum leak. Check the vac hoses under the dash and trace them to under the hood.
My wife's Wrangler has a 90 degree plastic vacuum coupler that failed, which allowed the vents to change randomly sometimes.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-16-2013, 06:10 PM
Re: a/c problem...
Ill find out soon cause ill be putting it back together. May have just been low on freon... seen it on a cavalier recently. Pretty strange but true. Ac was not cycling and sweating a lot. Got 1.5 lbs on recovery. Never would expect a low charge to cause 1 side to blow hot and other cold.. its just plain weird. All the doors are electronic no vaccum actuators.
Old 08-16-2013, 09:46 PM
brcidd's Avatar
brcidd brcidd is offline
Re: a/c problem...
Cavaliers don't cycle by design- they have a v-5 compressor that destrokes.
Evaps will vary temp from side a to side b- so yes when refrigerant is low- one side can be warmer than the other
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-17-2013, 09:45 AM
Re: a/c problem...
Yeah but if look at the air box the seperation doesn't accure until after the evap. Right before the heater core. So all air that passes the evap should be mixed on both sides. The heater core is what adjust the temp from side to side. Looking at the doors it appears the drivers side allows much more air into the core sooner which would be a design flaw in my opinion but I know they didn't suck this bad from factory.
Old 08-17-2013, 09:53 AM
Re: a/c problem...
Ok so here's the scenario. The blend door is shuting of the heater core its set at max cool. Both sides should have the same temp yet one side is much hotter than the other. This is amazing to me cause it doesn't make any sence. The cold air just prefers the passenger side and the driver side magically gets heated... LOL, shoot me please...
Old 08-17-2013, 06:10 PM
brcidd's Avatar
Re: a/c problem...
Vent temps different is a leading indicator of low charge on any vehicle- not just cavaliers- the evap is coldes on inlet side which just happens to feed the passenger side- outlet side feeds driver's side- refrigerant is all boiled off halfway through evap and no more cooling can be had after it boils- so put the right charge in it- find and fix your leak- (hint belly leaker on compressor and shaft seal on compressor)- been there done that..
'99 GMC Yukon
Old 08-17-2013, 10:20 PM
Re: a/c problem...
The air for BOTH sides passes THROUGH the evaporator. I don't understand what you mean by inlet and outlet. On almost all vehicles I've worked on if the Freon is low both sides are warm. Having different temps on different sides without a blend door problem was unheard of. These are newer models though and for some reason they behave differently it appears.
Old 08-18-2013, 04:29 AM
kevinande's Avatar
kevinande kevinande is offline
Re: a/c problem...
OP, here is your answer. Get yourself a set of guages and look at the charge levels. When you confirm it is low with guages, fill it to the appropriate level with refridgerant and you will be fine. As he also pointed out find your leak. and repair it, otherwise you will be experiencing this problem until you do.
1998 Escort ZX2
2004 Mazda RX8
2007 Honda Accord
2011 Ford F150
Old 08-18-2013, 09:47 PM
brcidd's Avatar
Re: a/c problem...
If you want to learn- then listen- I've seen your scenario over a a thousand times- low charge equals uneven vent temps- period--it happens in all cars, not just cavaliers- recover your charge and out the correct factory fill amount in it- then you see both sides cool correctly.....but be sure to fix your leak or it will happen tonight.
'99 GMC Yukon
Old 08-27-2013, 09:17 AM
Re: a/c problem...
Same problem.. also middle passenger vent has like no air flow!? Wtf god damn chrysler! Guess ill change the whole air box??
