Old 08-01-2013, 09:59 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
"buttons" for airbag, cargo lamp, etc not in place
how do I get this to go back in/stay in place?
This ain't your grandma's car!!
Old 08-03-2013, 08:20 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: "buttons" for airbag, cargo lamp, etc not in place
Push in on them and see if they lock in.
If not remove dash cover and see what is going on with there locks or hold down parts.
MT
Old 08-03-2013, 10:20 AM
Schurkey Schurkey is offline
First Guess: Retaining tab(s) have broken. If you can find them, it may be possible to epoxy/super-glue them back into place. Otherwise, a replacement panel may be in order--either new from the dealer, or scavenged from a salvage vehicle.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 08-03-2013, 11:24 AM
777stickman 777stickman is offline
If the locking tabs are broken, you can try some black silicone (RTV). Just a small dab at the 4 corners of each switch should do. Use a rag or paper towel to cover the switches and then tape securely to panel until silicone is cured. Carefully trim away the excess.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 08-03-2013, 12:21 PM
Originally Posted by 777stickman View Post
If the locking tabs are broken, you can try some black silicone. Just a small dab at the 4 corners of each switch should do. Use a rag or paper towel to cover the switches and then tape securely to panel until silicone is cured. Carefully trim away the excess.
FIFY. Silicon is not the same as silicone.
The Following User Says Thank You to Schurkey For This Useful Post:
777stickman (08-04-2013)
Old 10-21-2013, 03:41 PM
gw84's Avatar
thanks for the replies, I pulled the dash trim off and found that the tabs are indeed broken. So my new question is then, will the airbag "switch" come apart from the black square housing? (is the black piece alone replaceable? including the tabs that hold it in place)
