Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-01-2013, 09:12 PM
SuperDanny SuperDanny is offline
Rear (auxiliary) heater hose leak
Just discovered one of my rear heater hoses is leaking where the quick connect plastic fitting meets the metal crimp for the hose. This looks like a one piece section that runs from the rear heater core up near the front near a frame rail. Must be expensive.
So would anyone have GM part numbers (or diagrams) for these rear heater hoses or better yet, has anyone experience with cutting off the crimps on either side of the short rubber hoses in the back and simply replacing with worm style clams and new rubber hose?
I can't believe GM uses the stupid hose/crimp approach and quick connect. Just like the oil cooler tubes, they always leak!
'95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, CIA TriY headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
96 Buick Roadmaster Limited Wagon, mostly stock
74 Ford F100, 390 auto, longbed
98 Suburban LS 5.7L Vortec, stock
08 C1500 Suburban, 2WD
Old 09-02-2013, 04:51 PM
chuck's chuck's is offline
Re: Rear (auxiliary) heater hose leak
As you suggested, cutting the crimp off and installing a gear clamp will work fine. I have removed the crimp from my oil cooler lines, replaced the rubber hose and secured the hoses with gear clamps. I suspect that over time from heating and cooling the hose shrinks somewhat causing the crimp to be loose. The cost of a gear clamp will be cheaper than replacing the line.
chuck's
