Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-31-2013, 06:52 AM
mfb496's Avatar
mfb496 mfb496 is offline
Hot battery post!
Car wouldn't start the other morning and figured a dead battery but found it to be charged.Things are going haywire in the car lights blinking,relays clicking etc when i try to start it.Car was acting fine just a day prior and gave no indication that something was wrong.It's a 93 3.0 v6.I'm gonna pull the starter and check the wiring before i write it off.
Old 07-31-2013, 07:54 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Hot battery post!
Please be more specific about what was happening. What do you mean by "Hot Battery Post"? How did you determine that your battery was charged?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-31-2013, 12:53 PM
jamesslcx jamesslcx is offline
Did you make sure all your battery connections were clean and tight? Loose or corroded battery terminals can cause all kinds of problems.
The Following User Says Thank You to jamesslcx For This Useful Post:
Brian R. (07-31-2013)
Old 07-31-2013, 01:43 PM
mfb496's Avatar
put it on a charger and got a full reading then started my 454 chevy with it.battery cable is hot as if it was being overloaded.
Old 07-31-2013, 01:46 PM
mfb496's Avatar
gonna get in to now,looking for damage.more soon
Old 07-31-2013, 03:39 PM
mfb496's Avatar
corrosion.battery post eaten by acid.cable connections had oxidation.fine now with newer post and some cleaning with a wire brush.thanks dude.
