Old 07-30-2013, 06:45 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
removing dash to install stereo (cargo lamp, airbag, 4x4)
My '99 is the older style pickup. I can get the headlight switch off (just pushing it out), but I'm unsure how to remove the connections for the cargo lamp (looks like it's just a push tab) but then how do I remove the 4x4 buttons/wires and the airbag connections to remove the bezel?
This ain't your grandma's car!!
Old 07-31-2013, 09:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: removing dash to install stereo (cargo lamp, airbag, 4x4)
Connectors are push tab on side and some with a lock tab to be remove before you can push release tab or lift up tab on bottom
You will probably run into many more problems on the job.
I would suggest.
A All Data DIY online subscription should take you threw the hole thing.
MT
