Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 07-30-2013, 03:50 PM
Blues69 Blues69 is offline
2008 chev cobalt
how to change the front cv axle need help.
Old 07-30-2013, 03:59 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2008 chev cobalt
Separate the outer tie rod and ball joint from the knuckle. Remove the axle nut and separate the outer joint from the hub. May need to remove a brake line mount bolt from the body to allow for movement. Use a prybar to separate the axle from the trans. Pull the strut/knuckle assy out of the way and remove the axle shaft.
