Old 07-29-2013, 04:37 PM
angelfallen02 angelfallen02 is offline
vibration in my front end.
It started of with a vibration in my seat I had all my wheels checked the back driver tire thread was separating well I replaced it but now I have a really bad vibration on the front passenger side I replace all the rotors in the front I replaced the hub barring it was really bad I was told it bent the Axel so I replaced the Axel on the right but when I start to speed up hitting about 60 is when it gets bad and after I drove it for a bit the vibration gets worst and kinda hear a grinding/popping sound but the mechanics say it's nothing yet it wasn't doing it before could someone pleases help
Old 07-29-2013, 04:48 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: vibration in my front end.
May have a bad tire on the front also? When were they balanced last? Sounds like you need to find another shop to take a look at it...
Old 07-29-2013, 04:57 PM
I've had all the tires checked and balanced I've taken it to 2 different places I've drop almost a grand to get it fixed I need help
Old 07-29-2013, 05:43 PM
gmtech1's Avatar
Does the vibration get worse on acceleration? I have seen several of the GP's that had worn CV axle causing terrible vibrations. You cannot see the wear in the axles unless you disassemble and inspect the housings. I know you replaced the right side axle, but it's possible it's the left side.
Old 07-29-2013, 05:47 PM
Yes it does but it also appears to get worst the longer I drive how would I know I just had my Axel replaced
