Old 07-28-2013, 09:31 AM
rachelmorris rachelmorris is offline
Need Help! Something has fallen off (pics attached)
Nissan Micra year 1999- (had for 2 months) driving fine then heard a noise i've not heard before when using accelerator (I think). parked and looked underneath - see pics. any info/advice would be much appreciated! car novice
File Type: jpg 544447_10152250894232481_262723751_n.jpg (83.9 KB, 3 views)
File Type: jpg 581476_10152250894342481_47491040_n.jpg (58.4 KB, 5 views)
Old 07-28-2013, 06:39 PM
vgames33 vgames33 is offline
Re: Need Help! Something has fallen off (pics attached)
My first guess is the exhaust pipe has rusted apart. If that's what it is, I'm sure your car has gotten much louder than it was.
My other guess is that a trailing arm broke. You will notice handling problems and noise over bumps if that's the case.
The picture is very small/low resolution, so its hard to tell what that is. A larger/higher resolution photo with better lighting would help.
Old 07-28-2013, 07:07 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Looks like part of the exhaust heat shield, may be able to clamp it back on. If not have a exhaust shop look at it. If it's not in a critical area, like near a fuel line or fuel tank, remove the hanging piece and drive it.
Old 07-28-2013, 09:16 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
I agree that it appears to be a heat shield for the exhaust. A couple of large hose clamps, one forward and one aft, should work quite well to put that back in place.
-Rod
