Old 07-27-2013, 05:25 PM
aholen aholen is offline
How to repair beginning rust on the hood
Hi, I have some small damages on my hood, that's starting to rust and bubble. How can I fix this cheaply?
Best regards,
A
[Apparent spam signature removed by moderator]
Old 07-28-2013, 08:22 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: How to repair beginning rust on the hood
Since you're already getting bubbling, rust is forming under the paint. At this point, the only way to really repair it is to sand down to bare metal, properly prep the surface, and repaint. It is possible to feather this in and make it look decent, but it's pretty easy to remove the hood and paint the entire hood. You'd probably not find any body shop that is proud of the work they do to agree to do spot repairs, they'll want to repaint the entire hood.
Depending on how bad the bubbling is, the corrosion could be pretty deep already and require some filler or possibly even a new hood to make it look right.
-Rod
Old 07-29-2013, 03:06 AM
Chaise Chaise is offline
When rust is in a folded seam, replace it. It will never go away, and will come back quickly if repaired.
Tags
paint , rust
