Old 07-26-2013, 07:50 PM
vanhoogy vanhoogy is offline
Send a message via Skype™ to vanhoogy
Smile 1994 - New Compressor, Clutch Not Connecting
I just got a new compressor and everything was working fine. Yesterday I started the car, the blower was fine but NO cold air. I checked the charge and it is fine. Heard that it might be the relay?
Anyone want to give it a shot and thanks!
Old 07-26-2013, 10:01 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 1994 - New Compressor, Clutch Not Connecting
'94 H cars (as is yours) are known for relay contact issues-- tap on relay- usually 2nd from left on relay center on firewall- remove beautification panel to see relay center- if tapping on relay makes compressor come on- then replace it-- seen about 2 dozen H car relays act like this...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-26-2013, 10:02 PM
Tech II Tech II is offline
How did you check the charge?
What is the low and high side pressures with the compressor not running?
On a cold engine, pressures should approx be the same as the ambient air, i.e., if the outside air is 70F, both pressures should be around 70PSI......if much less you have a leak......
If pressures are ok, remove the 2 wire harness from the pressure cycling switch on the accumulator......turn car and A/C on......now jumper the two wire harness......if the compressor starts, and low side pressure does not drop below 28-30 psi, need a new switch.....if it drops below that, you need more refrigerant.....
Also, if the compressor was short cycling due to low refrigerant, a code 66 may be set in the ECM, and it is disabling the compressor....
Old 07-27-2013, 07:08 AM
imidazol97 imidazol97 is offline
AF -Advisor
You can switch relays in the center on the firewall. Most of them are single pole single throw like the compressor relay; the horn relay is in there and it's a good one to switch.
Just check the part number. Then if it works and the horn quits working, e.g., you know it's the relay.
Old 11-01-2013, 09:03 PM
Bassasasin Bassasasin is offline
Hopefully you won't have to go this far but I had a blown fuse that feeds the power to the compressor clutch. I caused it. On my car it was located in a rare place deep above the right passengers foot. It's amazing that the PCM can somewhat detect these blown fuses with a professional code reader.
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
