Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-26-2013, 11:10 AM
aleekat aleekat is offline
Codes P0442 & P0456 Simply Solution
2003 1500 5.7L. Found this fix on another dodge forum. Two hoses at charcoal canister located under drivers side just rear of the drivers seat. Check the two visible hoses. Mine was split at one end. Trimmed it off, cleared the check engine light. Has not returned. The hoses are cheap from a dealer if you need to replace.
The Following 2 Users Say Thank You to aleekat For This Useful Post:
Chris Stewart (07-26-2013), the61 (10-20-2013)
Old 07-31-2013, 01:19 PM
jamesslcx jamesslcx is offline
Re: Codes P0442 & P0456 Simply Solution
Great info, thanks.
Old 08-01-2013, 10:08 AM
Stolen from the other website: [IMG][/IMG]
The Following User Says Thank You to aleekat For This Useful Post:
Chris Stewart (08-01-2013)
Old 10-20-2013, 12:17 PM
the61 the61 is offline
I stoled a 2002 dodge ram with a Myers plow one with side tilt. it is in excellent shape 20 in. tires and rims but has a few bugs. One was $350 estimate to repair canister that kept the service engine light on. Crawled under today and visible split in hose was right where you said it would be. black tape fixed it. I'll get a new hose Monday. Paid $5000 for it. did I mention it has brand new tires.
Old 11-08-2013, 08:43 PM
I tore the front wheel well out last night found another hose completely split. replaced it with gas line for now but service engine light is out now.
Old 11-09-2013, 07:54 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Good work the61, thanks for the update!
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
