Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 07-25-2013, 07:08 PM
johnholl johnholl is offline
Question ABS ocassionaly activating when braking
Any ideas? Binding caliper or slide pins? very odd. No dash lights triggered.
Old 07-26-2013, 08:26 AM
maxwedge maxwedge is offline
A990 racer
Re: ABS ocassionaly activating when braking
Could be a bad wheel speed sensor a road test with a abs scanner connected can watch wheel speed inputs to see which one may be bad.
Old 07-26-2013, 03:34 PM
Tech II Tech II is offline
Occasionally activating? Does the ABS light come on when this happens?
Like Max says, if a code is set, it will at least direct you to one of the four wheel speed circuits that may be at fault.....notice I said circuit, not sensor....that means ANYTHING in that circuit....
If the light is not coming on, and no code is set, that is a tougher scenario to diagnose....
Old 07-27-2013, 10:03 AM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
Well.. If one wheel is getting more pressure than others it will lock, triggering abs. might try bleeding brakes as a starting point.
Old 07-27-2013, 02:46 PM
A990 racer
The only thing that normally triggers the ABs is a marked difference in wheel speed input such as one or 2 wheels locking, lower or higher pressure is not the issue unless it causes wheel lock.
Old 07-28-2013, 09:46 AM
Right, But if he has air in the system on three wheels, but not the one that is locking, then it would need to be bled.
Old 07-28-2013, 10:35 AM
If he has air in the system, then he has a leak....you fix the leak, you don't bleed the system first....
Intermittent ABS activation is usually cause by a signal problem, usually due to a speed sensor or wiring harness problem....
Old 07-28-2013, 10:43 AM
Like I said, So as a starting point, bleed the brakes.
One thing I have learned from being on this forum, Is we never know what the poster has done to the vehicle before they ask for help. For all we know, they could have opened all the lines up, and unwittingly let air in. Not saying this is the case. We just dont know.
Old 07-28-2013, 11:36 AM
No, haven't opened the bleeders. No, the ABS indicator does not activate. I may check and clean the speed sensor connectors. I fear that these speed sensors are integrated into the hub assemblies, and thus costly to replace. More of an occasional annoyance at this point.
Old 07-28-2013, 12:51 PM
Yeah typically they are. Depends on the vehicle you have as to the cost to replace. Some people will be adamant you buy timken hubs, others will say stay away from china made hubs. Personally, If your budget does not allow you to buy usa made hubs, buy what you can. Whether that be ebay or whatever, just be sure to torque the cv axle nut correctly on the front wheels, as this will lead to premature failure of the hub.
I bought MAC hubs from ebay for my 98 olds cutlass, 100 bux for a pair as I don't have any extra spending money, this was my only choice. Good luck.
PS. I would still bleed the brakes if you havent done so in the last two years.
Old 07-28-2013, 04:48 PM
Sleepy, you have bleed the brakes on the brain .....I have never solved an ABS problem, by bleeding brakes......only time I have bled brakes, is because of a leak, a repair, or just replacing the fluid....
Old 07-28-2013, 06:55 PM
Probably, but I like to start at the lowest cost easiest fix. Brakes probably need to be bled anyways, and if there is air in system, he will figure that out real quick.
Old 07-29-2013, 05:43 PM
I'll check the sensors when I get a spare minute. A previous post indicates 180 ohms. I'll check the condition of the wiring as well.
Old 07-29-2013, 08:17 PM
850-1350 ohms.....
The Following User Says Thank You to Tech II For This Useful Post:
johnholl (07-30-2013)
Old 10-02-2013, 06:14 PM
Gabito72 Gabito72 is offline
Hi
I have had that problem on the past on my 2005 equinox. It could be a loose sensor. Check if every wheel sensor is well installed on its bracket, if not, hang wires can be chewed when you rotate the wheels. That was my case.... It was easy to fix it.
I had the same problem with my 2003 Pontiac Grand Am GT
I hope this helps.
