Rear end noise
I have a 2007 4wd auto that produces a grinding sound from about 25 MPH up tp about 35-40 MPH.
I took it to a drive train mechanic who drove the car also heard the noise and indicated it sounded like the pinion bearing. This was a second opinion. Once up on the rack, he was unable to hear the noise. Pulled the inspection cover, oil was old but OK and no metal on the magnetized plug. Checked the rear wheel bearings, no problem. Checked the front wheel bearings, both replaced, both warn....thought the noise may have been coming from there, transmitted to rear of car. Checked all breaks including e-break.....all looked fine. To be on safe side, replaced front and rear diff. Oils. On the ground, Car still makes the same noise. Tahoe from hell, any ideas? Thanks, Dave |
Re: Rear end noise
Re: Rear end noise
Thanks for your reply.
Yes, according to my mechanic, they had sound devices placed "all over the car". I would assume that the pinion bearing would make noise in the air (on the rack)? |
Re: Rear end noise
front hub bearings are a well known failure item for sure . sometimes you just can't feel it so run it till it gets a little louder.. the grinding could also be the transfer case. check fluid for a blue color if black that could be the problem. |
Re: Rear end noise
Thanks for the input. Oil in both cases was changed. I'm leaning more to the pinion bearing base on input from the forum.
DH |
