Old 07-24-2013, 01:23 AM
oldsgmc oldsgmc is offline
engine crankshaft question k1500 93 tbi
I bought a 93 k1500 that was blown up. Replace engine to find out heads are bad and knocks.got another engine out of a 96 pickup vortec 350 with 50k on it. (Both engines were free and i payed 40 bucks for carb to tbi adapter plate so im not in it much yet)Before I put it in I found spun bearing on number one. Its not tearably loose or scoren but it is bad and im going to fix it. My question is if I buy the intake to adapt my tbi on top and a new 383 stroker crank and lower end bearing will this cause issuses because everything else is stock in that engine? Would like to keep the costs down but i will spend the money to avoid problems, also its gonna be a weekend cruiser/tow something if needed truck
The stroker crank is the same price and a new stock crank is the reason I ask
Thanks for input,
Jon
Old 07-24-2013, 09:50 AM
maxwedge maxwedge is online now
A990 racer
Re: engine crankshaft question k1500 93 tbi
You need pistons and connecting rods with the stroker, do your research on what it takes to make up a 383 from a 350.
Old 07-24-2013, 09:46 PM
Schurkey Schurkey is offline
If you're buying the TBI-to-Vortec intake bolt pattern intake manifold, you'll also need a way to route exhaust gas into the EGR system from one of the exhaust manifolds.
GM sold a "kit" that included a specific exhaust manifold and (I think) some tubing. The exhaust manifold was a regular-production item, but I don't know the application. At any rate, that manifold had a port on it that could be used to send exhaust gas to the intake manifold.
A look through an older GMPP catalog would probably get you the part numbers needed.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
