Old 07-22-2013, 06:07 PM
BuckyGMC BuckyGMC is offline
1990 Civic DX 1500 Will not start.
My Daughter's old faithfull did the other day and I am trying to bring it back to life.. It spit and sputtered and died on the road.. Timing is fine, newer belt, Distributer replaced 1 year ago, replaced, wires, coil, plugs.. It Gets fuel, Compression was at 90 for all 4 cylinders, but I had not turned off the fuel, which explains the low pressure some.
It has good Spark. If you pull the plugs you can smell the gas, and I even tried some starting fluid.. No oil in the coolant, no coolant in the oil, and the the car leaks and does not burn any oil..I do not understand why I get nothing, I do not have the equipment for a leak test.. I appreciate any help..
Old 10-09-2013, 03:27 PM
Eriedipper's Avatar
Eriedipper Eriedipper is offline
Re: 1990 Civic DX 1500 Will not start.
Any chance the Catalytic Convertor could be plugged?
This happened to me after I rebuilt my Son's 1990 Civic Wagon.
Disconnected the exhaust & it fired right up!
Old 11-29-2013, 10:33 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Check the rotor, I've had a few cars where the screw for the rotor inside the distributor comes out and the rotor just free spins.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
