Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 07-20-2013, 10:31 PM
camaro_nut camaro_nut is offline
90 sunbird 2.0turbo no injector pulse
I have a 2.0 turbo with no injector pulse.it has a new fuel pump and filter.will run off of carb cleaner.new ingnition module and has 12v to injectors.all injectors have been tested and work. Can't tell if its ecm or distributor.put noid light on and doesn't flash when cranked.any sugestions before I buy a $160 distributor and$75 ecm
Old 07-22-2013, 12:00 PM
Tech II Tech II is offline
Re: 90 sunbird 2.0turbo no injector pulse
Since you are getting spark, it's not the distributor.....either you have a bad ignition module in the distributor which is not providing a reference signal, you have an open wire between the distributor and the ECM, or you need an ECM....
You would need a scan tool to see if you are receiving the reference(rpm) signal from the ignition module in the distributor.....If your car has a tach, that may show rpm's while cranking, but the tach gets it's signal from the coil not the ignition module in the distributor.....
Old 07-27-2013, 05:51 PM
Got car running.after checking everything out I unplugged the map sencer and it fired up and runs fine.it does spit and spudder alittle but new map sencer should fix that
