Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-17-2013, 08:55 AM
mfb496's Avatar
mfb496 mfb496 is offline
cooling leaking!
Anyone have the hydraulic type with their v6? Have you had it leak? What was the cause? I think mine is leaking at the fan by the banjo fitting.
Old 07-17-2013, 12:16 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: cooling leaking!
Are you leaking coolant or power steering fluid? I don't think your description of the problem is adequate.
If there is a leak at the banjo fitting, you can try torquing the fitting (47 ft-lbs) to see if that helps. Otherwise, you need to remove the bolt and install a new gasket.
There are also shaft seals and housing cover O-ring that can leak.
Be forewarned, the fan mounting nut to the motor is reverse threaded.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-17-2013, 02:17 PM
mfb496's Avatar
Brian I just de-greased it and just as you say.Banjo gasket may be leaking powersteering fluid.Gasket available over the counter?
Old 07-17-2013, 02:39 PM
Brian R.'s Avatar
Resident Chemist
Yes, probably only from Toyota. Try torquing the bolt first.
Old 07-18-2013, 08:50 AM
mfb496's Avatar
Hey Brian! When I got home this morning I decided to try what you suggested.At first I was hesitant.After hitting the banjo with a 1/2 ratchet and it was super tight.I pulled it apart and found the gaskets kinda warped.Maybe it was too tight.So I swapped them around and re-torqued them and so far so good.Thanks for the advice.
Old 07-18-2013, 11:52 AM
Brian R.'s Avatar
Resident Chemist
Next step is just a new gasket if you're sure that is the source of the leak.
