Old 06-08-2003, 10:21 PM
blade34609's Avatar
blade34609 blade34609 is offline
muffler position
I have a 1990 Civic LX 4 door.
I have a GTSpec muffler which is just like the Apexi N1 muffler.
I know how in the 4 door the piping is bent sideways and out the left side of the car.
Can I just skip the custom pipe bending and just run it straight out to the RIGHT side of the car? Or would it sit too low?
Thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 06-08-2003, 10:23 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
just run it out the right ... it will be just fine ... if I could do mine again i would do it out the right also, cause right now it comes out the left, but has like 90 degree pipe bends to get it there.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-08-2003, 11:10 PM
dirtydx dirtydx is offline
ask 1PHATCX, his bumper had a section cut out.. looks good.
heres a pic
"I just threw away a lifetime of guilt-free sex and floor seats to every sporting event in Madison Square Garden. So, please, a little respect, for I am Costanza, Lord of the Idiots."
Old 06-09-2003, 12:08 AM
blade34609's Avatar
What if I dont cut out the muffler section and just bolt it under there anyways?
Will it still fit correctly and not touch ground too low?
Thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 06-09-2003, 01:05 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Thanks,
Owen
You might melt your bumper if it to close to it
My Name is Roberto AKA. Berto
Old 06-09-2003, 01:11 AM
91civicDXdude's Avatar
its going to sit a lot lower because theres no groove in the rear end on the passenger side..
Old 06-09-2003, 01:18 AM
it wont work. either cut a hole, or bend the piping to accomadate the drivers side.
i've seen ppl do a 45 degree angle out the drivers side, that also works.
Old 06-09-2003, 08:53 AM
blade34609's Avatar
Is there any size pipe I can buy that will be possible to bend without a pipe bender? My muffler has a 2.5" inlet so can I must buy some 2.25" pipe and bend it correctly?
Then weld it on?
Thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 06-09-2003, 09:11 AM
׿Pyro¿× ׿Pyro¿× is offline
Send a message via ICQ to ׿Pyro¿× Send a message via AIM to ׿Pyro¿×
I dumped mine on the passenger side because my muffler was too big. My mechanic put it on and it sits fine and doesn't rub or heat my bumper or anything. Just check out my pics.
Jameson
Old 06-09-2003, 11:17 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
big bear, that exhaust has to get hella hot to melt that bumper, meaning if it melts the bumper from being close to it, you got something messed up. Mine sits really really close to the bumper and it doesn't melt it at all.
My opinion if your gonna run it out the passenger side, cut the bumper just like there is a cut out on the drivers side. Take the piece you just cut out, and put it on the drivers side. Takes a little bit of work, but they should have some bumper repair kits at a parts store and you could use that to replace that piece to the drivers side.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 06-09-2003, 09:57 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
heres a pic
i've been violated!!! holy fawk thats an old pic, u got some profile goin on me or something now? hehe
yea theres a cut out on my bumper, looks VERY sick and very sexy hehe
i just fiberglassed over the existing hole tho. i should dig up a better pic for u, gimme a few mins
Old 06-09-2003, 10:06 PM
1PhatCX's Avatar
heres one
Old 06-10-2003, 12:02 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
damn man, and i thought my last hatch was rough! i give you props though, you arent scared to take a saw to it
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-10-2003, 02:20 AM
Old 06-10-2003, 06:19 PM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
naw fuk that, just replace it to the stock side (left) and instead of making it go straight out just kick it out to the side a little bit like a wrx or eclipse. thats how i did mine and it looks hotter then if it were straight out.
Y LOOK FAST WHEN YOUR NOT?????????
