Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-06-2013, 10:11 PM
RadioBuff23 RadioBuff23 is offline
Ignition Switch! Help!?
Just got done installing the ignition switch on my 02 Malibu. Car starts up and runs fine, the only problem is that when I take the key out of the ignition. The car still thinks its in and continues to beep. I Checked and made sure that everything else in the car was off, and it still continues to beep and won't let me lock the car when i open the door because it believes the key is still in the ignition. I double checked and made sure all the wires were plugged in properly and still have the same issue. What is going on?
Old 07-07-2013, 08:16 AM
slls slls is offline
Re: Ignition Switch! Help!?
The new switch must be faulty.
Old 07-07-2013, 09:04 AM
autojoe autojoe is offline
did you have same issue with old ignition switch?
Old 07-07-2013, 12:04 PM
Replaced both the ignition switch and the lock cylinder last night, did some troubleshooting and realized the new lock-cylinder was bad. The chip was bad and setting off the alarm. Went and got it warrantied got another one and the new lock cylinder worked great. Gotta love technology.
Old 07-07-2013, 01:24 PM
Tech II Tech II is offline
Correct terminology?
The lock cylinder slides into the PassLock sensor/module....together as a unit they slide into the ignition switch.....I assume it was the PassLock sensor/module that was replaced, not the ignition switch?
Old 07-07-2013, 08:36 PM
are you serious?we know what he meant.he knew what we meant.
Old 07-07-2013, 09:45 PM
Unfortunately, I guess I didn't.....using the the right terminology prevents confusion....
