Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-04-2013, 08:18 AM
Samtollison Samtollison is offline
Vacum leak
I am new to this and needing some help. I recently replaced the head gaskets in my 2003 Malibu. First time and all seems other than it runs rough at stop lights. The check engine came back on and so I had it read and there is an air flow issue. Nis there anywhere that I can get a schematic for the vacum lines? I have all over and cannot seem to find a loose or broken one. Any other suggestions are most welcome. Thanks
Old 07-04-2013, 09:55 AM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
Re: Vacum leak
Congratulations! You have had dexcool eat to you head gasket. Be sure and change that coolant out before 100k. Best to use some other type of coolant, I use walmart brand 8 BUX. Anyways, Go here, http://www.justanswer.com/chevy/2khu...ratically.html, This seems to be the setup of my 3.1l, 1998. It should be pretty similiar, but Who knows. There is always a pesky vac line right below the coil pack that gets unplugged on mine, its pretty touch sometimes to get it plugged back in.
Im also sure a haynes or Chilton would have the vac diagram in the back of the book,
The Following User Says Thank You to SleepyHead98 For This Useful Post:
Samtollison (07-04-2013)
Old 07-08-2013, 12:14 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Vacum leak
What is the state of your EGR gasket. This can cause problems if left off, or defective.
Old 07-08-2013, 02:34 PM
autojoe autojoe is offline
Re: Vacum leak
vacuum.jpglean code or massairflow code?Maf codes p0101,p0102,p0103?disconnect MAF connector and see if runs better.enclosed vacuum diagram.
