Old 07-03-2013, 04:27 PM
ianc911 ianc911 is offline
Putty Recommendations?
Hi folks,
I'm looking for a recommendation for some decent putty. I'm finding recently that doing the body work to get ready for paint is one of the most exasperating, time-consuming processes of building the car, and I'd like to eliminate this frustration if possible.
I've been using the Squadron green and white putties along with the Tamiya white putty and they are just hopeless: they shrink and crack and will not fill smoothly in one application. It's putty, sand, putty, sand, putty, sand, etc. and it's wearing me out!
I've heard people say that anything except two-part putties will always shrink, so I applied at my LHS for some Tamiya two-part putty and they said they couldn't order it here in the US?
Does anyone have a recommendation for anything obtainable in the US that is easy to sand and work with and won't shrink or crack? I've also read about talcum powder and super glue, but I'm not too crazy about experimenting with that actually...
Any automotive products, or something specifically for the hobby that will work better than what I've been using? Really getting frustrated here... Thanks for any help,
ianc
Old 07-03-2013, 05:01 PM
stevenoble's Avatar
Re: Putty Recommendations?
I use Isopon automotive 2 part fillers and they are great. No shrinkage at all, easy to sand and shape. Much, much better than any model putty I've used. I also use superglue, the thick gap filling kind and set it either with an activator or by sprinkling baking powder onto it. Try it, it sounds silly but it works a treat. Once I've done the main filling, I prime, then apply 3m Acryl Glazing putty, which dries very fast and takes care of any little pinholes left behind that the first filler missed.
Steve Noble
Old 07-03-2013, 10:13 PM
MidMazar's Avatar
MidMazar MidMazar is offline
My favorite two putties are Milliput 2-part epoxy putty and tamiyas polyester putty. The polyester putty worksgreat for small and fast projects like seems, gaps and irregularities. Milliput i use for extensive body work, takes a while to dry. But this allows you to shape it. Both putties are 2-part so you haveto combine them together, a little more work but worth the effort and money.
Tamiya basic putty and mr.hobby putty are also good but more like squadron style.
In Progress
Old 07-03-2013, 10:49 PM
Twowheelsrule Twowheelsrule is offline
I have used Milliput 2-part epoxy putty and while it works well, it was a bit tedious to get the portions and parts mixed IMO.
I have since found Aves 2-part epoxy putty that comes in two equal containers. It works almost the same as Milliput, but it is easier to scoop out in equal amounts and is very soft and pliable.
Here is a Youtube of someone using the putty. http://www.youtube.com/watch?v=rpxoOJtWBAg
Old 07-04-2013, 05:38 AM
Foxerjr's Avatar
Foxerjr Foxerjr is offline
Two part automotive putty is one of the best and least expensive body putties you can use. bondo professional glazing & spot putty (2-part) is available in small tubes just right for modeling. It's fine and sands similar to plastic. Most automotive putties come in containers way to large for our uses.
I do also use one part Bondo. The key is using the right product for the right job. For thin coatings and small repairs one part is more convenient and works just fine.
Old 07-04-2013, 07:52 AM
sitwhiteysit sitwhiteysit is offline
I just bought some 2 part stuff from the auto paint store the other day called dolphin glaze. I think it's great.
Old 07-04-2013, 08:30 AM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
I´m from the oldschool too.
Milliput (standard and superfine) is always the best. And I deadly love its oldstyle british carton little box, never changed since 40 yrs
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 07-04-2013, 09:36 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
i still use tamiya putty (gray) for the surface work (filling in small gaps). if i do need to fill a large area or make things like extended fenders, what i use is either epoxyclay wood* (2-part epoxy that you mold like clay and is used for woodwork - http://www.usoriginalhardware.com/pr...clay-wood-28g/) or the regular epoxyclay* (can't find a pic, but it's similar to the wood one). they dry solid in about a few hours and are easily sandable, though the latter is better when wetsanding (the wood one tends to absorb the water for a bit). i also use a cheaper one, which is bostik 2-part epoxy mixed with some talcum powder, though you have to reshape this once in a while during curing this as this can get runny and distort (especially if there's not enough powder to thicken it). it is easily sandable though once dry and is as rock-hard as things can get.
*these are available in the philippine market, not sure what your local equivalents would be
olly olly oxen free
Old 07-04-2013, 11:50 AM
petesy petesy is offline
Back when I was in Toronto I just used generic 2-part glazing putty sold in hobby shops. They worked like a charm and I have had no shrinkage with them.
Now I use mostly Tamiya and Modeler polyester putty for large area works, and Gunze Mr Surfacer for sink marks and small scratches.
Old 07-04-2013, 04:16 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Milliput Standard (Yellow-Grey) is definitely my favorite putty. It has great adhesion properties, it's very strong, yet still easy to sand into shape after it has cured. Also, if you have a dehydrator you can speed up the cure time from 6 hours to 45 minutes.
-Mike
Old 07-04-2013, 04:28 PM
John18d John18d is offline
I use primarily Miliput for shaping putty like for making flared fenders and I use Tamiya "white" putty for smoothing out pin-holes etc - I let miliput and Tamiya putty dry for 24 hours before I sand on them. Both of these give excellent results.
John
Old 07-08-2013, 01:55 PM
Thanks for the recommendations guys! I asked about Milliput at my LHS and the owner said that he had tried some, but it had already hardened on its journey over from England so we wouldn't order it anymore. The automotive products, particularly the Bondo in the small tube sound interesting, so I'll be investigating them at Pep Boys soon. Thanks again,
ianc
Old 07-09-2013, 05:14 AM
zak78's Avatar
zak78 zak78 is offline
ianc
That's an odd comment on the Milliput from your LHS owner. I've been using the same box of Milliput, in the same terrible little plastic bags, for six years, with no problems. Same ugly yellow-green stuff. Great results every time.
Old 01-29-2014, 05:10 AM
joelwideqvist joelwideqvist is offline
I'll post in this thread for a similar question.
I have a build where i will attach a resin fender to a swing arm made of plastruct parts.
After that I want to fill and shape the area inbetween the parts, which will be a bit fragile. I therefor want some sort of putty that is easy to fill with and shape and doesn't dry unsandable. A lot of you mention Milliput but on the contrary I find it pretty hard to sand
Old 01-29-2014, 06:41 AM
zak78's Avatar
Did you let it dry for the full six hours? I've tried using a dehydrator to speed up its curing rate, but that didn't work for me. Even at five hours, it doesn't feel right to me. I've had great luck with it, but never without the full six hours of drying time.
