Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-01-2013, 01:45 PM
hakachukai hakachukai is offline
Question 2004 Malibu Intermittant Battery Light
I have a 2004 Chevy Malibu Maxx that randomly dings and shows me the battery light.
It usually happens when going uphill or during really hard accelerations.
It is also showing OBDII code P0621.
The car has no other issues. Always starts, always runs well.
What causes this problem? Where should I start looking? I'm thinking it's probably a bad connection somewhere.
Old 07-01-2013, 02:39 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2004 Malibu Intermittant Battery Light
Check the wiring harness closely between the generator and the PCM. If it all looks ok, and if this is a V6, you can try and insulate the B+ wire from the back of the generator where it runs past the ignition module/spark plug wires. Use Nickel tape, or something comparable (the tape is a little pricy). It's possible that the B+ wire is picking up voltage from the plug wires. It's also possible there is a problem with the PCM, but since it only happens on acceleration I would lean towards something else.
Old 07-01-2013, 06:38 PM
Do you happen to know which pins I can check on the PCM connector?
I don't have a service manual for this car :-/
Old 07-02-2013, 08:36 AM
Tech II Tech II is offline
Does your vehicle have a voltage gauge? If yes, what is the voltage when your light comes on?
If the voltage is dropping, then you either have an alternator or PCM problem....
Old 07-14-2013, 06:04 PM
Update on this issue:
I shielded the + alternator cable that runs under the ignition wires to the battery. I used aluminum foil 4 layers thick and grounded the shield to the engine. I've checked it for proper ground using an ohm meter several times. It's definitely working.
The problem seems to happen less, but it still happens.
I installed a volt meter inside the car and watched it while I was driving. When the battery light comes on the voltage does not change at all. It's right about 15v the whole time. I'm using an analog meter, so it's hard to tell exact voltages. but it's accurate within a volt or two.
I connected the meter between engine ground ( right behind the alternator bracket ) and the + battery cable at the alternator.
I tried re-creating the problem by wiggling the wiring harness around, but have failed to do so :-/
Still looking for a solution
Old 07-14-2013, 06:05 PM
Old 07-14-2013, 06:06 PM
Old 07-14-2013, 06:07 PM
Old 07-14-2013, 06:10 PM
According to my Haynes manual code p0621 means: alternator L-terminal circuit.
What does that mean? I don't see it labeled on a schematic anywhere in the book :-/
Old 07-14-2013, 07:27 PM
Old 07-15-2013, 04:19 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Does the Horn work? The Alternator and Horn seem to be on the same circuit!
Did you change Spark Plugs with aftermarket ones? I know it sounds weird but theres info on it here http://www.hptuners.com Seem to be an issue with Vettes, but it may help you diagnose better.
Seems to be a problem with Diesel Trucks too!
I would take the Alternator out and take it to AutoZone or Advance Auto and have it tested. If it checks out good, you can move to wiring and PCM.
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Tags
2004 , battery , chevy , light , malibu
