Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 06-29-2013, 11:40 AM
pcabn pcabn is offline
05 Chevy Uplander
Have ABS Traction control lights activate at times ABS codes are C0035 C0036 C0253. Has 120,000 miles on van measured resistance on abs sensor on wheel hub 1064 left side 1071 on right side. I'm doing brakes and due to mileage am relacing wheel hubs anyways but I don't know if that will correct this. The last code talks about a steering sensor. Can anyone tell me where to find that and how to test it? Thanks
Old 06-30-2013, 09:34 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 05 Chevy Uplander
The C0035-36 are both for the L/F speed sensor. Your readings are ok, so the problem is most likely in the harness that plugs into the sensor. They break right where they make the bend up and secure to the control arm. Replacement harnesses are 70-80 bucks from a dealer.
The C0253 indicates a problem with the steering position sensor, located at the bottom of the steering column. This sensor requires the use of a scanner to accurately diagnose. I have replaced several of these sensor for failures.
The Following User Says Thank You to gmtech1 For This Useful Post:
pcabn (06-30-2013)
Old 06-30-2013, 06:54 PM
Do you suggest a dealer scan it? I replaced the wheel hubs due to age and wobbling. That has cleared the ABS code. I did not see any physical defects in the harness. Doesn't mean there isn't any. As of now the codes are not back. If the steering sensor needs replaced is this something I can do? I've been looking for the replacement procedure but haven't found it yet. Thanks for any help.
Old 06-30-2013, 07:54 PM
Tech II Tech II is offline
After the sensor is replaced, you need a Tech II scan tool to "center it"...
The Following User Says Thank You to Tech II For This Useful Post:
pcabn (07-01-2013)
