Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-25-2013, 01:28 PM
kevin23 kevin23 is offline
fuel supply problems
93 Mercury GM 131,000
Can squirt fuel in throttle body and it starts, then dies as that fuel is burned.
I cannot hear the fuel pump when turning on ignition switch. (Even stuck my ear to the fill tube and had someone else to turn on the switch, nothing)
The "crash " button in the trunk is depressed as it should be.
With a test light I could not get any voltage from the "crash" switch.
Fuel pump relay under the hood, I pulled the relay out slightly, just enough to get the test probe in. Got voltage on one leg only, don't know if I should get voltage on the other legs, but think that I should.
Really need some help here, I'm lost. Thanks
Old 06-26-2013, 12:36 PM
Re: fuel supply problems
Solution: 20 amp fuse blown , located under hood, passenger side fender well, inside black plastic box.
Old 06-27-2013, 09:14 AM
miamibob's Avatar
miamibob miamibob is offline
Glad to hear you got it fixed for relatively little money and fuss!! Thanks for reporting back on it.
