Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 3
Old 06-23-2013, 05:39 PM
chrisorbics chrisorbics is offline
1972 Beetle Auto Clutch will not go into gear while running
Hi, I am trying to help out my neighbor with his beetle. I tested the wire right at the shifter and it gets battery voltage when pulled back and none when released. I assume that is working properly.
I then investigated further to find a diaphragm on the transmission with a bad vacuum line. After replacing it the transmission will still not work when running.
What should I check and how does this auto clutch work?
Old 06-27-2013, 09:25 AM
Re: 1972 Beetle Auto Clutch will not go into gear while running
Is there anyone one here that has worked on they old bugs before
Old 07-08-2013, 11:24 PM
I applied vacuum to the diaphragm and the clutch works and the car goes into gear while running. The engine has vacuum while running. The solenoid has power so I think that it has an internal problem. I am having trouble finding this part locally.
