Go Back   Automotive Forums Car Chat > Daewoo > Lanos | Kalos
Old 06-21-2013, 06:30 PM
earthgirl earthgirl is offline
manual to automatic transmission change
hi. ..My lanos has manual transmission..i read an Ad that can change from manual transmission to automatic,is that poasible and safe?? Will there be any future problems if i did that? And do i have to take any precautions? Any help and information is highly appreciated cos am excited about having automatic transmission but dont know much about his process!
Thnk u
Old 12-07-2013, 05:11 PM
Lanos Driver Lanos Driver is offline
Re: manual to automatic transmission change
Swapping a manual for an automatic is not as simple as it may appear. Your car's computer is programmed for manual transmission, an automatic needs the brake interlock, the shifter won't be right, and that's just a few issues. Why not just trade cars for one with automatic?
Old 11-07-2014, 01:27 AM
LeoTheLion89 LeoTheLion89 is offline
Send a message via ICQ to LeoTheLion89 Send a message via AIM to LeoTheLion89 Send a message via MSN to LeoTheLion89 Send a message via Yahoo to LeoTheLion89 Send a message via Skype™ to LeoTheLion89
i wouldnt worry about the brake interlock its a PITA anyway. Common sense is you apply the brake BEFORE shifting out of Park anyway so its rather pointless. To convert expect to spend over a grand for the auto transmission alone. you would also need to buy a Automatic Shift assembly. You would need to also get a Automatic Shift cable (which may or may not be hard to find) any transmission shop or mechanic should beable to do the swap. Best best is to ASK a mechanic if it is even doable and then how you would go about doing it expect it to cost around 2 grand. As far as the clutch pedal that can be removed. The Lanos has the same sized brake pedal regardless of manual or auto maybe have the old clutch pedal rigged as another brake pedal so u can have a "Wider" pedal?
