Old 06-21-2013, 11:58 AM
miranda neon miranda neon is offline
timing help?
ok i have timed this 94 blazer before and with no problems.but i just did the head gaskets, and i cant get it in time. I set it at tdc(compression stroke) and the timing tab is sitting in between the 2 timing marks. I can get it to start and run, but that's by putting it at tdc and then the dizzy at plug wire 6 6. then when i connect the wire(passenger floorboard) it all goes to hell
the harmonic balancer hasn't slipped, or sheared the key off to be honest, last time i timed it i dont remember putting it at tdc, i lined up the 2nd mark to the timing tab dropped in dizzy on 1 and reconnected wire and she ran,
Old 06-21-2013, 03:13 PM
NHRA's Avatar
NHRA NHRA is offline
Re: timing help?
you still have to time the distributor
Old 06-21-2013, 03:27 PM
Re: timing help?
but if the timing marks at tdc arent lining up to the timing tab, then how can i move to the dist? and when i drop the dizzy pointing to cyl 1 when its at tdc, it wont fire?
Old 06-21-2013, 08:08 PM
maxwedge maxwedge is offline
A990 racer
Re: timing help?
Sounds like 180 out? Sorta bullet proof here, if all the wires are in the right place in the cap, you are on tdc compression rotor points to # 1 thats it, final timing done with brown wire disconnected.
Old 06-21-2013, 09:29 PM
Re: timing help?
ok well which timing mark should i be using theres 2
lets say number 1 sits at 3o clock, and number 2 sits at 12oclock. which one should be by the tab?
Old 06-22-2013, 09:05 AM
A990 racer
Re: timing help?
If you mean the marks on the tab, should be able to read 0 or 10 degrees, no? If on the balancer when the piston reaches tdc., use a straw thru the plug hole to feel tdc, then you will see which mark.
