Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-19-2013, 07:38 AM
back2life's Avatar
back2life back2life is offline
suspension problem
hi guys need some help..i have an 01 deville (base) with the air level shocks in the back. i took out originals and replaced with Gabriel Hijackers. my old airline would have worked but the ends were seized/ rusted into old shock so i had to cut them. my question is can i use an aftermarket air shock line to replace them from the pump? also dont even know where pump is located but havent looked yet either lol. or can i use the cut line with 2 new o-rings even if the line doesnt have that flared end nomore?
Old 06-19-2013, 09:19 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: suspension problem
I have spliced pleanty of air lines using 1/8" compression fittings from NAPA, just use a small pin to help open up the hole in the plastic line after you cut it. Use a razor blade or sharp knife and a sawing motion to avoid really crushing the line when you cut it. The pump is under the right rear of the car, above the muffler.
Old 06-19-2013, 11:32 AM
back2life's Avatar
thanks for a prompt reply GMtech.....i was thinkin of goin all the way to the motor but if u say the splice will work, i'll try it! so do i just get regular brass compression fittings like we normally use on metal lines or is it special ones for plastic lines?
Old 06-19-2013, 11:36 AM
gmtech1's Avatar
Yep, the brass ones are what I use, haven't had a problem with one yet.
Old 06-19-2013, 11:40 AM
back2life's Avatar
should i do the splice in any particular location?
Old 06-19-2013, 11:49 AM
gmtech1's Avatar
I usually do it where the line comes out from the plastic inner liner in the wheel well and goes up to the shock.
The Following User Says Thank You to gmtech1 For This Useful Post:
back2life (06-19-2013)
Old 06-19-2013, 12:33 PM
back2life's Avatar
Thumbs up Re: suspension problem
YOU THE MAN GMTECH!
