Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 06-15-2013, 09:55 PM
rayray84 rayray84 is offline
99 Durango transmission
ok I really hope someone can help. I have a 4x4 5.2L 99 Durango. Everything was running great and the all of a sudden I started it to go to work one morning and it would not move. Now its making a grinding/whinning noise when its not in park, it tries to move when I put it in gear but has the grinding/whinning noise and is real sluggish. Then after its running for about 5 min it wont move or go in gear at all. Im so frustrated. I have had reg. transmission fluid changes and was running great. now this. Ive checked the fluid and its full to. Its my only family ride and we have 6 kids. can someone please please help me and tell me what it could be?
Old 06-16-2013, 03:48 PM
jamesslcx jamesslcx is offline
Re: 99 Durango transmission
Check engine light on? If so are there any codes?
Old 06-19-2013, 02:18 PM
Thank you for responding!, No its not on. I used my code reader to check for codes anyway but none came up.
Old 06-19-2013, 02:20 PM
Oh, also I dropped the fluid pan and it has some metal shavings in it, which I think is normal? But it smells burnt really bad.!
Old 06-19-2013, 04:23 PM
rayray how did your tranny filter look when you dropped the pan? Sounds like it is due for a servicing, the filter could be clogged.
Old 06-20-2013, 06:30 PM
it was full of gunk. Completely blocked from what it looks like.. that would be great if that all it is. could that cause the grinding and sluggishness.
Old 06-21-2013, 01:30 PM
That filter being gunked up could have been starving the trans of fluid and holding pressure very low. Newer trannys are sensitive to stuff like that.
Old 06-21-2013, 03:00 PM
Ok, Thank you very much, i get paid again in two weeks and im going to give it a new filter and fluid again and we will see what happens. Thank you very much for your help! I will let you know how it turns out. Thank you Again.!!!!
