Old 06-15-2013, 06:30 PM
DOUGLASNC DOUGLASNC is offline
Brake booster replace
Hi, Need instructions on how to get old brake booster off a 1991 Lumina with a 3.1 engine... Can't figure out what tool to use to remove the four bolts holding it to fire wall as clearance is so tight a swivel socket won't go on nuts.Also, will steering collum have to come down to get brake peddle loose? Bought some of those wrench end thingies that you stick a 3/8 drive extension on that favors a distributor lock down wrench i'm hoping will work..Almost no brakes, and hear lots of air at brake peddle.Engine races when brake is applied.Bleeding didn't help, so I figure it's the booster...Any help would be appreciated....
Old 06-16-2013, 09:20 AM
Schurkey Schurkey is offline
Re: Brake booster replace
The booster is held to the body with a twist-on, spring-clip arrangement. You'll build a simple "special tool" to twist it back off the firewall.
Boosters are a common problem on the early W body. I replaced boosters on a '92 and a '93 Lumina Euro 3.4 which had a different failure than yours, but were still defective. Be very careful of the brake light switch. You may have to drop the steering column in order to re-set the adjustment of the brake light switch. It is very hateful on my '92. Write-up and lots of photos starting at Post 11 ('93), and Post 18 ('92) at:
http://www.w-body.com/showthread.php...stopping-power
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 06-16-2013, 11:48 AM
Thanks Schurkey! Just what I needed to find out.Woundering if a piece of 2x4 will turn it off. Will check it aou. Again, you'r right on time with you'r helping hand, and I appreciate it a lot.
Old 06-22-2013, 08:17 PM
Job done, and again; thanks for you'r insight..It was a bear getting that booster rod hooked back to the brake peddle. All seems to work ok, so I guess I did it correctly.Thanks so much for you'r help.
Old 06-23-2013, 08:43 PM
You done good.
My '92 kicked my ass due to the hateful design of the brake switch. The '93 wasn't so bad.
