Old 06-15-2013, 04:25 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
1988 Corvette
I’m building a replica of my Mom’s first Corvette using an old AMR 1/43rd scale white metal kit. It has been on the to-do list for almost 20 years, but since the kit did not have to correct wheels to make her car, it sat. Until I figured out how I could make the right wheels.
I made the outer rims from brass tubing. I made the centers also from brass using the etching process I have been fine tuning.
I made decals for the center caps. Still some clean-up to do…
The kit’s tires were hard and brittle; I test fitted one to a rim from the kit and it promptly (and as expected), split in half. I repaired it and made a mold of the four kit tires and cast a new set in soft rubber-like resin. Until fully cure (about a week) they tend to get all sorts of dust and junk stuck to them. The dust will wipe off before I need to install them on the car.
Old 06-19-2013, 04:47 AM
Greeno666's Avatar
Greeno666 Greeno666 is offline
No Pain No Gain
Thumbs up Re: 1988 Corvette
Good start, Bro
If no one didn't made it,go built it.
Thailand Modeler
See my page >>>https://www.facebook.com/Greeno666
Old 08-06-2013, 10:01 PM
Re: 1988 Corvette
Above average interior parts for this kits contemporaries. Still Spartan compared to a traditional plastic kit… All white metal, with some brass in the chassis.
Old 08-07-2013, 02:50 AM
sportracer02's Avatar
Re: 1988 Corvette
These wheels look great for 1:43
Micha
Old 08-09-2013, 01:52 PM
Re: 1988 Corvette
Thanks!
The body was cleaned up, but not as well as I’d like since it had already been assembled (by someone else before I got the kit). The individual body parts were not prepped fully and the epoxy bond is stronger than the white metal’s integrity.
I used Testors Gloss White enamel as the base color. Now to start detailing the mostly black trim…
Old 08-09-2013, 09:34 PM
Re: 1988 Corvette
The black window and beltline trim are done. Decals for the emblems and side marker lights are up next.
I made a decal for the front panel where a license plate “might” go, (barely visible). It is the word Corvette in relief so I tried for a shadowed effect.
I used a dark gray wash over the front parking lights. It seems to work OK since it is a white car and those lenses are an off white…
Old 08-10-2013, 04:00 PM
Re: 1988 Corvette
The door handles have been blacked out and the decals applied as well. I made a replica license plate too.
The taillights had to be filed down to about 30-35% of the thickness they came in the kit. They looked like they were from a ’53 Corvette(?).
Glass is in, waiting for the paint to cure then it is time for final assembly…
