Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-15-2013, 01:33 AM
jyount jyount is offline
Onstar brain?
I need to know where it is. My sub is has the RSE dvd player. Kids need it. It is fine, the connector off of it and it still had a drain on the "info" fuse. That fuse feeds the VCIM and the overhead dvd thing, so I would just like to unplug the onstar. Don't use it anyway.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 06-15-2013, 11:45 AM
Re: Onstar brain?
Found it. I pulled the instrument panel pad off the top to make sure it was the right module. You can get to it by folding down the glove box. Two connectors. It said right on it "3 amp" when on. Funny that my draw was three amps.... Disconnected it and put the fuse back in, no draw. Connected it again to make sure, that was it. A blue point fuse buddy inline with the ground cable worked tons better than a test light. It showed amp draw instead of a bright/dim test light.
Current job: RN
Wife's
