08 Taurus X SEL Break light stays on
Break light stays on unless I lift the break peddle up when Ieave the car. My cruze control stopped working and the traction control light comes on after driving for a few minutes. Thanks for your help in advance. I can't find any manuals for this truck.
Re: 08 Taurus X SEL Break light stays on
The improperly adjusted brake pedal switch is probably the source of all these issues. I think if you adjust the switch or replace it that will take care of the light staying on, the cruise not working, and the traction control light.
-Rod |
Rod thanks for your help, I could not find manuals for this truck. How would I adjust the break pedal switch and do you have diagrams for proper replacement procedures.
I do have the factory manual for your Taurus X but I'm currently on vacation this week and do not have access to the manuals.
Generally the brake pedal switch is pretty easy to replace and, if you have a test light, easy to test. This is probably a fix you don't need to be too nervous about starting to tackle. If you get stumped, it will likely happen before you get to a point of no return. -Rod |
| The Following User Says Thank You to shorod For This Useful Post: | ||
movaughn (06-18-2013)
meets the break switch and it fixed the job. There is no traction light and the cruze control works. Thanks again Rod. Movaughn |
