Old 06-11-2013, 12:05 PM
rkvons's Avatar
rkvons rkvons is offline
SuperCharger oil leaking.
Hey guys, I got a question for ya. I have a '98 Grand Prix GTP coupe. I park it on a level spot and remove the little allen wrench plug to add supercharger fluid and I fill it with the right stuff from GM up to the level of the hole and then I put the plug back in. Everything is good so far. But then I park on an incline towards the passenger side and some oil leaks out. It comes out of the little brass breather in the center of the drive pulley. Why does it do that? I've never messed with that. I have changed the fluid though. Thanks in advance.
Old 06-11-2013, 06:15 PM
rickisrad rickisrad is offline
Re: SuperCharger oil leaking.
There is a snout seal that should fix that.
http://shop.zzperformance.com/store/...nout-Seal.aspx
rebuild instructions.
http://www.rollingperformance.com/snoutrebuild.htm
video of snout seal replacement.
http://www.youtube.com/watch?v=ICw-6MTcsBM
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
The Following User Says Thank You to rickisrad For This Useful Post:
rkvons (06-12-2013)
