Go Back   Automotive Forums Car Chat > Toyota > RAV4
Old 06-11-2013, 11:50 AM
reefgeorge reefgeorge is offline
Coolant leak that I cannot find
I have a coolant leak that I cannot find and can only see from under the truck. It is dripping down onto the front steering and the exhaust "S" curve. It appears to be coming from almost straight up on the side of the engine facing the back of the truck but I cannot see the source. The water pump does not appear to be leaking after removing the serpentine belt but not the pulley.
I am hoping that this is not the dreaded leaking head gasket with stripped head bolts.
Any ideas?
Thanks,
George
2002 Blazer, 4 dr, 2wd, 199K miles
2003 Rav4, 4 cyl, 239K miles
2012 Mailibu, 4 cyl, LTZ, 85K miles
Old 10-23-2013, 08:42 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Coolant leak that I cannot find
Put some fluorescent dye into your coolant and check the rear of the engine with a black light in a dark garage or at night. The point of leaking should be obvious. It is most likely a hose connection.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-23-2013, 10:59 AM
Will do, thanks.
