Old 06-10-2013, 03:26 PM
Robmoo Robmoo is offline
The ABS light is on
On my 2005 3.3L Grand Caravan the ABS light keeping coming on. I inspected the sensors for the front and used my compressor to give them a quick puff of air to get rid of dust. The light went off for about 5 days. Now it is back on.
How does one read ABS codes? If I knew for sure that the problem is a speed sensor and which one I could clean or replace the faulty sensor.
If I clean to sensor are there any special precautions I need to take? As far as I could see they didn't look very dirty.
Thanks,
Rob
Old 06-10-2013, 03:39 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: The ABS light is on
You read ABS codes with an ABS capable scanner. Should cost around $200. You could check resistance through the internal coils with an ohmmeter. Just two contacts on the connector. You should see some resistance but not sure what. An open or short means it's toast. Compare the 4 and if one is vastly different that may be your culprit. Course with the intermittent nature it may be just a loose or dirty connection.
Is it heat related meaning does the light come on after driving a distance or does it have a mind of it's own?
Here's some examples. You want a scanner that can read multiple code sets and not just ABS:http://www.amazon.com/s/ref=nb_sb_no...Aabs%20scanner
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
