Old 06-05-2013, 06:17 PM
azzanione azzanione is offline
Question No vacuum at the vent selector
My daughters 2000 Grand Am's 2.4l, vent selector is not working, right now all the vents are wide open. I took the control panel off and found that I wasn't getting any vacuum from the back of the knob, took the passenger underside and glove compartment off found the vacuum lines and wasn't getting any suction from there either. I have no idea where the vacuum should be coming from, I suspect either a bad hose or canister but I have been unable to locate it . If anyone has a diagram for the HVAC vacuum lines or has had this problem any help would be appreciated. Hope someone has the answer cause i really don't want to take the whole dashboard assembly off.
Thanks
Chris
Old 06-05-2013, 07:34 PM
Tech II Tech II is offline
Re: No vacuum at the vent selector
The emissions label in the engine compartment shows all vac lines....
Do you smoke? Disconnect vac line from control head and blow smoke backwards to find the leak...
Old 06-06-2013, 03:34 PM
Thanks for the response, but yeah I been told that unfortunately it's no longer there. Someone out there has to have the Service manual Volume one (I have volume 2) which shows the HVAC vacuum diagram. Any help, pictures, drawings, crayon sketch something that will lead me in the right direction.
Thanks again.
Old 06-10-2013, 01:48 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
their is a vacuum canister on the passenger side, under the hood. And the vacuum diagram is right their on the strut tower brace. i'll try and get a diagram of this posted ASAP
1999 Grand Am SS 3.4 OHV
Old 06-10-2013, 03:02 PM
That would be great, the car was evidently repainted and what ever was there is gone.
Thanks
Old 06-12-2013, 01:29 PM
here is the diagram. i would search for broken/cracked vacuum line(s).
The Following User Says Thank You to xeroinfinity For This Useful Post:
azzanione (06-15-2013)
Old 06-15-2013, 11:20 AM
That did it, found the accessory vacuum line to be cracked, repaired it and now it all works. Thanks for all the help could not have done it without the diagram.
Old 11-21-2013, 01:42 PM
naldo03 naldo03 is offline
hello
I have the same problem only the center vent blowing air not lower and defrost...any help would be appreciated...mine is 01 Pontiac grand am gt 3.4L
thanks
Old 11-21-2013, 04:52 PM
aleekat aleekat is online now
Originally Posted by naldo03 View Post
hello
thanks
Did you look at the diagram and check the vacuum lines?
Post back, that's what makes Forums Work.
Old 11-21-2013, 07:56 PM
Check the one marked "accessory vacuum".....
Old 11-22-2013, 01:16 PM
is it the same diagram on 3.4L? I found some vacuum hose but I have no idea which one controls the heater/ac vent selector..
Old 11-22-2013, 06:18 PM
No the diagram is different.....should be one, on one of the strut towers....
Old 12-26-2013, 06:57 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
I have a 2003 grand am gt 3.4 and last year i was not getting any heat when i turned the controls, come to find out my Air Vent Blend Door Actuator was bad. Was very easy to replace. Maybe just keep that in mind for the future
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
