Old 06-02-2013, 10:08 PM
army army is offline
1998 buick lesabre steering pump
I need to replace power steering pump very noisy can anyone give me some advise do I need to get under car to disconnect hoses or take other parts off to make it easier for me, any advise would be appreciated thanx
Old 06-03-2013, 12:25 AM
enslow enslow is offline
These links may help:
http://www.automotiveforums.com/vbul....php?t=1077384
http://www.3800pro.com/forum/fwd-tra...ack-re-re.html
Get an AlDelco pump, and bleed the initial air out by turning the pump by hand first, than cranking but not starting the engine. Rigging a vacuum adapter to the pump reservoir (use no more than 20 inches vacuum) really helps get the air out.
Sent from my GT-P3113 using Tapatalk HD
Old 06-03-2013, 08:12 AM
Tech II Tech II is offline
Re: 1998 buick lesabre steering pump
But is the pump noisy because there is air in the system?
Old 06-03-2013, 10:06 AM
That's a very good point. You may also find flushing the PS fluid corrects the problem. I would do this before replacing the pump.
