Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 05-31-2013, 09:45 PM
michael6390 michael6390 is offline
wheel bearing to replace??
brakes that arent seized but wheel nuts very hot and car has lack of power
wheel bearing to replace? thanks
Old 05-31-2013, 10:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: wheel bearing to replace??
Do the wheels spin freely when they are in the air?
Old 05-31-2013, 10:50 PM
yes, no problem. caliper and pads ok
Old 06-01-2013, 02:37 PM
jamesslcx jamesslcx is offline
It could be bad brake lines. What year is the vehicle? How many miles?
Old 06-01-2013, 05:02 PM
hyundai accent 1997 with 72000 miles
Old 06-01-2013, 06:18 PM
Michael, any kinds of noises such as roaring while going around turns?
Old 06-02-2013, 10:27 PM
no nothing special
thanks
Old 06-03-2013, 01:19 PM
No noise of any kind probably rules out wheel bearings. Probably caliper pins are rusty causing the brakes not to fully release or bad brake lines.
Old 06-03-2013, 07:59 PM
usually on a car, is it normal that wheel nuts become hot? but not to burn fingers, right?
Old 06-04-2013, 12:42 PM
Michael, they can get pretty warm but if they are hot enough to burn you that's another story. When you raise the vehicle and spin the tires do you feel some resistance? A little is ok.
Old 06-06-2013, 05:37 PM
no all is ok. I took time to see all the break system and wheel bearings. on the passenger side, castle nut for bearing was unscrewed and since I screwed it some noise when I'm running with the car.
went to see mechanic. no oil contamination, no overheating. the only one thing that could be is master cylinder that not working well.
thanks
