Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-30-2013, 10:55 PM
mavrick1974 mavrick1974 is offline
Speedometer issues 06 Ram 3500 4wd Diesal
can anyone help?? I have an 06 ram 3500 diesel. speedometer does not work and the abs light, brake light, and check engine light is on. I have changed both speed sensors and checked for breaks in the wire.... any one... please! Thanks in advance.
Old 05-31-2013, 08:00 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Speedometer issues 06 Ram 3500 4wd Diesal
You can get a free diagnostic scan from most chain type auto parts stores.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-01-2013, 11:23 AM
Thanks but I do have a code scanner it gives me 0500 (speed sensor) so I changed both but still the same issue. I am wondering if it is the PCM since this all happened at once when the trailer I was pulling had a frame break and shorted out the system, I did change the fuses but no luck. Is there a hidden in line fuse that I haven't found? I don't know of any way to check the PCM directly but it is a very expensive part to just swap out and be wrong.. thanks again in advance.
Old 06-01-2013, 07:51 PM
AF - Advisor
Do the brake lights work?
Does the Cruise Control work?
Have you checked the Rear Wheel Speed Sensor on the differential housing?
Old 06-01-2013, 09:23 PM
yes I have changed both sensors one on the dif and the one on the tranny. Breaks are working but no cruise control
Old 06-04-2013, 12:29 AM
A quick update and a special shout out to Chris Stewart and corvett69! These chaps lead me in the right direction. So it turned out that when I lost my trailer brakes I used the "SPARE" fuse to regain my braked, well well well..... it apparently aint no spare it was the problem all along!! and to think my next step was gonna be to drop 6 bills on a PCM.. WHEW thanks again chris stewart and corvett69
Tags
abs , light , sensor , speed , speedomeeter
