Old 05-28-2013, 08:50 AM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
Vibration and noise when turning left under load
2000 3.5L
On a hard left high speed turn, it vibrates under load.
Also while under throttle when making a second gear left hand turn.
Noise will come and go when going over dips at high speeds under load
I have already replaced the left Halfshaft.
I am a master mechanic and have had success with changing a halfshaft on a similar situation. Looking for other possibilites before I throw another halfshaft at it.
Old 05-28-2013, 09:24 AM
Tech II Tech II is offline
Re: Vibration and noise when turning left under load
Bearing noise?
Old 05-28-2013, 10:03 AM
Originally Posted by Tech II View Post
Bearing noise?
Don't think so. It is only under load. Also sounds like a lower sound than that
Old 05-31-2013, 07:02 AM
stretch80 stretch80 is offline
Does the vibration problem occur when starting from a dead stop and accelerating with the wheels partially turned. That was my problem and it was a failed front motor mount. 99 intrigue with 212 miles and original half shafts and wheel bearings
Old 05-31-2013, 07:18 PM
It does, but also turning left only
Old 05-31-2013, 08:28 PM
Can the engine mount be checked visually when installed?
Old 06-09-2013, 08:48 PM
O.K. I replaced the right side CV axle last week and am certain the problem is gone now. The inside joint had water in it and the smaller part of the boot slid on the shaft when compressed.
Old 06-09-2013, 09:32 PM
Good work.....thanks for posting the fix....
