Old 05-27-2013, 10:22 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
HVAC vents not changing
hey guys. went to use my A/C last night when i noticed the MAX A/c wasnt working. It would blow cold air, but it would not go into recirculate mode. Then after that i noticed air just came out of the front vents and floor only, no matter what position the switch was in (floor, vent, defrost) The switch still makes the a/c compressor kick on when its switched to max a/c or defrost, but the vent position doesnt change. I checked all vacuum hoses under the hood and everything looks fine, (although i couldnt find one specifically that goes right into the HVAC unit) I paid special attention to the areas around the spark plugs and wires i recently changed, but couldnt find anything suspicious.
Any suggestions on where to start? Also, can anyone tell me where under my hood i would find the vacuum line that goes to the HVAC
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 05-27-2013, 01:58 PM
Re: HVAC vents not changing
NEVERMIND. Just found the vacuum line i was asking about. apparently it runs near the battery, where corrosion from the battery can fall/drip on to the line and cause it to corrode/melt.
The Following User Says Thank You to jakegday For This Useful Post:
jamesslcx (05-27-2013)
Old 05-30-2013, 08:56 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Good find, I had the exact same problem and traced it to my battery area.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
