Old 05-25-2013, 08:04 PM
trox trox is offline
2.2 A/T park switch jump
I have a 2000 2.2 with a bad auto trans that is removed from the truck. I want to sell the truck and show the engine runs good but it won't crank because of the Park/Neutral switch not getting made. I have the 2 connectors at the switch on the side of the the trans and I think it's the 6 pin connector I need to work with. What wires do I ground or jumper to get it to crank and run?
Old 05-26-2013, 09:12 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2.2 A/T park switch jump
I would just jump 12 volts to starter solenoid small wire.
Most of the time I tap into purple starter wire on top of engine.
MT
Old 05-26-2013, 10:41 AM
Thanks MT, can I leave the 12 volts hooked up and use the key as normal?
Old 05-26-2013, 03:50 PM
Smile Re: 2.2 A/T park switch jump
never mind, I thought about it and realized this was just for cranking. It worked good, thanks MT
Old 05-27-2013, 07:29 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went.
MT
Old 05-31-2013, 09:36 AM
I spoke too soon. I started it 3, maybe 4 times. I used a lead from the small starter terminal to the battery positive. Each time I started it, if I didn't catch it on light off and keep it going for a couple seconds, it would die and I would have to re-cycle the key to prime the pump again. Now it won't stay running at all after the initial light off no matter what. It's like if I hold the lead on the battery it would keep going but that's keeping the starter engaged so I can't do that. Could I have blown a fuse? Is it the pump that's not running once it gets going. I ran for several minutes before this for 3 or 4 times.
Old 05-31-2013, 04:20 PM
MT-2500's Avatar
AF - Advisor
Check all fuses and ign power.
Does it have the key on 2 second fuel pump prime up?
MT
Old 06-05-2013, 08:53 AM
Yes it has the FP prime up and that's about how much of a start I get. A short light-off and depending how much throttle I have input, how high it revs then immediatly quits. I have to turn the key off and back on to get it to light off again, otherwise it just cranks over. So, I have ignition and temporary fuel. What kept the fuel pump running when I first did this? I didn't question it before but now I'm wondering.
Old 06-05-2013, 11:28 AM
MT-2500's Avatar
AF - Advisor
Check fuel pump fuse and relay.
MT
