Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-25-2013, 09:21 AM   #1
jesselv
Possible fuel sender problem on my 01 Rodeo
I believe my fuel sender could be going bad but not sure. It kicked out the code(can't remember the code #) where one of the options was fuel sender sending out a high voltage. But this code was set at least 3 years ago and the thing is still running. It only recently bogged while going uphill-only happened the one time- so maybe that was caused by something else. Also, there is a strange noise now emanating from under the hood that almost sounds like a vacuum leak- like air being sucked thru a straw. The sound for some odd reason goes away after driving for about 5 minutes. Anyone have similar problems with there Rodeo? Could the sound I mentioned be associated with a bad fuel sending unit?
jesselv is offline   Reply With Quote
Old 05-25-2013, 02:47 PM   #2
amigo-2k
Isuzu Guy
Re: Possible fuel sender problem on my 01 Rodeo
That sounds it probably a broken intake manifold gasket and it is sucking air through a small hole, one it warms up it seals itself and the sound goes away ...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
