Old 05-24-2013, 11:22 PM
mcollier101 mcollier101 is offline
engine surging
I have a 99 Grand Am GT 3400. Just starting doing this, when you start the engine, it starts surging rhythmically as if you are pushing on the accelerator and letting off. When I put it in gear, I have to have the brake firmly pushed down as it lurches forward severely. I haven't driven it far, but it seems once you get going it runs fine. Any ideas?
Old 05-25-2013, 09:37 AM
Tech II Tech II is offline
Re: engine surging
Sounds like a vacuum leak.......also pull the vac line off the fuel pressure regulator and see if there is fuel in the line.....
Scan for codes....
The Following User Says Thank You to Tech II For This Useful Post:
mcollier101 (05-25-2013)
Old 05-25-2013, 05:28 PM
Re: engine surging
I checked vacuum and found one off. Did not solve the problem. I removed the fuel pressure regulator expecting some gas to come out of the line but none did. I replaced the regulator with a new one. I restarted and had the same problem, I did however feel the fuel line was empty and might take a few moments to get back up to snuff. I let it run and after about a minute and a half, all went smooth and the check engine light went out. Took it for a test drive and all seems okay. I do wonder if there isn't an underlying problem (perhaps a fuel pump). For now it seems okay, thanks for the advise.
Old 05-25-2013, 06:15 PM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
Re: engine surging
I wouldnt think so (Fuel problem and what not). I would think it would either be vac leak or sensor. Usually IAC (Idle air control). TPS could cause a problem too. But usually a code will be thrown for those.
Im not really surprised the surge went away after a while, once the computer relearned how to act once you plugged the hose back in.
